Someone gimme an answer please, this shit is not supposed to move right??
Brake plate
Re: Brake plate
tighten that bolt sheesh
Re: Brake plate
Which bolt? I dont see anywhere to tigthen that part? Help me dude please haha
Re: Brake plate
normal, how it increases brake power is bad ass, how it works? cant tell ya, some kinda leverage.
Re: Brake plate
It's supposed to be a friction fit, it's the auto-centering mechanism for leleu hubs.
That's loose, but maybe would be fine.
Re: Brake plate
Drags like crazy on my hubs. Are they both just fucked? Should ive just got a new one?
Re: Brake plate
I bought the unpainted one used to stop my brakes dragging. The exact same thing is happening to this plate though. That plate is just very loose. Would a new one move like that or be locked down?
Re: Brake plate
More than likely your issue is not the plate. It swivels like that to center itself and apply even pressure to both pads.
If you wanted to make it move less, you could take a punch and stake down the corners of that rounded rivet on the cover, but it still needs to move.
Re: Brake plate
Its 100% the springs dragging on the hub.
Re: Brake plate
brake shoe springs are over extended, the pivot slides are worn.
Re: Brake plate
Everything you need to know.
Want to reply to this thread?
