Re: motobecane
Jack M /
got the new carb saturday i think its a deltora 1.5 or something? also came with intake and new cables. should i install it and try to get it to start or should i just drop the engine and order new rings crank bearings, gaskets and seals.
not sure here. i doubt its going to start at 50-60 psi. i know there is a big air leak somewhere. the other day i put some oil in the plug hole just to get things a bit lubed up and most of it drained out of my stator while turning over, which leads me to believe the crank seal on that end has the biggest leak so it just ran out of there. not ran but dripped i should say. reguardless i dont think she will fire up.
