> Steve Davies Wrote:
> Ye I heated the case first and put bearings on crank first is there a
> difference in bearing size between the bearing on ignition side of crank
> and the small case side? The cases are all bolted back together but the
> crank is not spinning as free as it should
Did you put the bearings in the case, or on the crank first?
