The bearings are the same size one has the c3 tolerance. I’ve had the crank feel tight in the case before when it was installed. While the cases are hot after they are bolted together tap the small case half over where the bearing sits with a mallet it usually helps seat the bearing and allows the crank to spin free.
Re: Ciao crank bearings
