Vespa grande
MICHAEL FRENCH /
Hi everyone, first post here. I've been lurking a little trying to understand these little beasts more.
So where I stand I'm about to acquire a vespa grande from my dad who's the original/3rd owner. I rode it and beat it up as a kid, and when my dad told me he was going to take it to the dump I told him I'd take it being sentimental.
Anyway when it was put under the house at a vacation home about 15 years ago it needed fuel line(s) for sure. Which I would appreciate if anyone could tell me what size I need to buy for it.
Also since this thing hasnt been ridden in probably 20 to 25 years what else do I need to inspect before I attempt to start I. I never realized they have a transmission untill I was lurking here so obviously I need to check fluid. Is there anything else that I'm dumb and overlooking before I fire it up when I get it home? (edited)
Re: Vespa grande
MICHAEL FRENCH /
Ok so looking at pictures my dad in his short lived attempts to get it running pulled all the plastics and a chain, I'm ASSuming the chain is for the pedals not variator, if so what size chain will it be? Standard bicycle or something else cause in the pictures the chain looks STIFF
Re: Vespa grande
For your information and reading pleasure :
https://www.mopedarmy.com/wiki/Vespa_Grande
Don't overlook downloading the manuals . ;)
Re: Vespa grande
https://www.google.com/url?sa=t&source=web&rct=j&url=https://vintagemopeds.files.wordpress.com/2013/10/haynes-ciao-and-bravo-repair-manual.pdf&ved=2ahUKEwiL-r_UrK_gAhVEjoMKHcTZDM4QFjABegQIAhAB&usg=AOvVaw0DNlsesMIkU1p-qM3t80g4
That's what you want. It is for Ciao/Bravo, but the Grande drive train is nearly identical.
Yes, the chain is a bicycle chain.
For transmission fluid I use 80/90 high pressure gear oil. Get synthetic and it won't smell as bad.
There are basically two special tools you will want from treats: flywheel puller and there is a freewheel wrench. Both are worth the money.
Re: Vespa grande
id pull the covers, take out the petcock and check the tank/frame condition.
Re: Vespa grande
Mike, any updates on your Grande?
