Tomos main drive gear
Anyone ever run a tomos with just the one needle bearing in the main drive gear?
Cheers
Re: Tomos main drive gear
♣Slew Foot♣ /
It will either eggbeater the pedals or just grind and grate the kick start sprag collar/pedal shaft
♣Slew Foot♣ /
Get a whole preferably newer main drive gear not replaceable without expensive tools or a vast amount of labor
Cheers for the response. Since typing the original post I managed to get the bastard bearing out :) I thought that I had done this already ages ago but whenever I'd press a new bearing inside it would squash and warp so ended up just giving up and using my old drive gear with worn side teeth so I could only start the bike but not pedal. turns out the cage of the needle bearing was still in there. Very happy now ordered a new bearing so I'll soon be able to pedal again.
There should be an O ring between the 2 needle bearings, without it you will leak transmission oil badly from the lefts side pedal shaft.
