Garelli Rally SL 86 with no spark
Filipe Goncalvas /
I have a garelli 86 and I can get it to get spark, I have cleaned the points, New ignition coil, new spark plug. I just don’t know what to do anymore?
Re: Garelli Rally SL 86 with no spark
Ground the blue wire coming out of the stator and see if it fires.
I had a rally once and it didn’t have spark, so I changed the light bulb and it had spark
Filipe Goncalvas /
It worked thank you so much Stephen
If that worked the problem is in your tail light. Either the wire is unhook, wires hooked up wrong or the brake light bulb is blown. Could also have a tail light without the resistor in it.
Want to reply to this thread?
