Re: Sachs Hercules engine problems
gener hernandez /
just finished lapping the decomp valve,issue is its quite bent,about 1mm ,but it actually worked,no leaks now, another problem,i have a new china clone 12mm carb,and every time i try to start the engine it overflows, i have a very clean tank,and cleaned the petcock,also new rubber hose,can't seem to check the problem,will lightly lapping the float needle valve tip to seat it logical to do,cheers
