Re: Sachs Hercules engine problems
P D /
> Born to be WillD Wrote:
> check that the seal around the float bowl isn't leaking also. I've had a
> number of clones leak because the float bowl gasket bulges or cracks.
> also float height may be off. you can check seal on the float easily by
> removing the carb from the bike, take the float bowl off. put a clean
> fuel line on the carb and holding the carb upside down (so the float's
> weight is pushing it closed) try blowing into the fuel line. should be
> completely blocked and the float should be siting nice and horizontal.
> parallel with the carb. you can lift the float by hand while blowing on
> it and very directly observe if and when the flow is blocked, and this
> can be a great way to identify and troubleshoot carb leaks. If it all
> seems totally fie but still leaks, it's almost definitely the gasket. or
> leaking around one of the connects
I have to ask : Do these carbs normally sit at much of an angle ?
If the float level is set correctly , fuel should not reach the gasket if the carb is even close to level .
