Re: Sachs Hercules engine problems
Born to be WillD /
> P D Wrote:
> > Born to be WillD Wrote:
> > check that the seal around the float bowl isn't leaking also. I've had
> a
> > number of clones leak because the float bowl gasket bulges or cracks.
> > also float height may be off. you can check seal on the float easily
> by
> > removing the carb from the bike, take the float bowl off. put a clean
> > fuel line on the carb and holding the carb upside down (so the float's
> > weight is pushing it closed) try blowing into the fuel line. should be
> > completely blocked and the float should be siting nice and horizontal.
> > parallel with the carb. you can lift the float by hand while blowing
> on
> > it and very directly observe if and when the flow is blocked, and this
> > can be a great way to identify and troubleshoot carb leaks. If it all
> > seems totally fie but still leaks, it's almost definitely the gasket.
> or
> > leaking around one of the connects
> I have to ask : Do these carbs normally sit at much of an angle ?
> If the float level is set correctly , fuel should not reach the gasket
> if the carb is even close to level .
No angle, the square bings the seal is below the fluid level. just barely, or really pretty much right at it. but if it's not got a good bowl gasket it leaks. its retarded. square bings are dumb carbs.
