Re: Vespa Grande Rear trans rebuild instructions?
ELLAK MOLNAR /
Still sitting on my work bench in the garage, Still really cold here in Ohio. Also, I'm trying to figure out how to remove the small rear chain sprocket from the rear wheel. I have the thin 36mm wrench required to remove it. What I don't know is if the threads are reversed or not to remove it? from what I understand, That thing is on there tight from years of usage. Has anyone removed that rear chain Sprocket on the right side of the rear rim?
  Vespa Grande Rear trans rebuild instructions?Topic by: ELLAK MOLNAR ELLAK MOLNAR 02/14/19 08:50AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: pat splat pat splat 02/14/19 09:00AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: Dirty30 Dillon Dirty30 Dillon 02/14/19 09:22AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: ELLAK MOLNAR ELLAK MOLNAR 02/14/19 12:29PM
  Re: Vespa Grande Rear trans rebuild instructions?Re: Dirty30 Dillon Dirty30 Dillon 02/14/19 12:45PM
  Re: Vespa Grande Rear trans rebuild instructions?Re: ELLAK MOLNAR ELLAK MOLNAR 02/14/19 12:50PM
  Re: Vespa Grande Rear trans rebuild instructions?Re: Les B. Les B. 02/20/19 09:50AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: ELLAK MOLNAR ELLAK MOLNAR 02/20/19 09:59AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: Dirty30 Dillon Dirty30 Dillon 02/20/19 10:11AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: ELLAK MOLNAR ELLAK MOLNAR 02/20/19 10:19AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: Dirty30 Dillon Dirty30 Dillon 02/20/19 10:23AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: ELLAK MOLNAR ELLAK MOLNAR 02/20/19 10:55AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: Dirty30 Dillon Dirty30 Dillon 02/20/19 11:05AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: Les B. Les B. 02/21/19 09:48AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: ELLAK MOLNAR ELLAK MOLNAR 02/21/19 10:42AM
  Re: Vespa Grande Rear trans rebuild instructions?Re: ELLAK MOLNAR ELLAK MOLNAR 02/22/19 02:56PM
