Re: Sachs G4 505 / 1D engine rebuild
MPB Andyrew /
> Born to be WillD Wrote:
> rebuilding that motor is easy, can be done in like 2 hours even as a
> first timer.
> Use an impact drill to pull the clutch and stator nuts (or a rope or
> some other piston stop to keep the crank from turning) flywheel puller
> is the only special tool you need. buncha 5mm allen bolts on bottom,
> pull it all out slide off the seals and pop off the bearings, replace it
> all. shits are cheap and easy to come by. goop it and reassemble bam bam
> bam. I just rebuilt 2 sachs motors in my basement last week, doing a
> third maybe tonight.
I'd argue a bearing puller is also a special tool you'd need.
