> Owen Sims Wrote:
> Where do I find theese tools, I can’t find any online
You aren't going to find the factory tools.
Get yourself an electric impact wrench to get the clutch and main gear nuts off. It's a great tool and you will find uses for it forever. Or you can put the cylinder back on and use a piston stop, but there is mild risk of damage.
Get a small 2/3 jaw puller to pull the main gear off.
Look on treatland for the garelli flywheel puller. Iirc, it's 19mmx1mm
I think that's all the special tools you'll need
