Re: Just bought and the pedal start won’t work
DrGeorgeTompson (Alan) /
It should work, yes. I personally think that's kinda expensive but whatever. I put mine in the holes on the main gear. You might need some heat. They are on tight and tend to pop off pretty violently.
I also suppose you may not need to remove the flywheel if you are just splitting the case to examine the chain.
The case gasket should be .5mm thick. You can run it without a gasket and use some kind of sealant instead, but the crankshaft and other shit can bind so I don't recommend it.
  Just bought and the pedal start won’t workTopic by: Owen Sims Owen Sims 02/21/19 07:09PM
  Re: Just bought and the pedal start won’t workRe: Mike Bully Mike Bully 02/21/19 08:17PM
  Re: Just bought and the pedal start won’t workRe: Stephen Simmons Stephen Simmons 02/21/19 08:37PM
  Re: Just bought and the pedal start won’t workRe: Born to be WillD Born to be WillD 03/05/19 09:28AM
  Re: Just bought and the pedal start won’t workRe: Stephen Simmons Stephen Simmons 03/05/19 10:15AM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/21/19 09:23PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/22/19 08:33AM
  Re: Just bought and the pedal start won’t workRe: Dirty30 Dillon Dirty30 Dillon 02/22/19 11:00AM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/22/19 10:37AM
  Re: Just bought and the pedal start won’t workRe: Ryan . Ryan . 02/22/19 02:50PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/22/19 03:54PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/22/19 04:05PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 02/22/19 04:18PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/22/19 04:55PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/22/19 05:00PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/22/19 05:04PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 02/22/19 06:02PM
  Re: Just bought and the pedal start won’t workRe: Aaron Ward Aaron Ward 02/22/19 05:08PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/22/19 06:42PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 02/22/19 06:51PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/23/19 01:56PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/23/19 05:36PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/24/19 10:13PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/25/19 08:54PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 02/25/19 10:19PM
  Re: Just bought and the pedal start won’t workRe: Gator San Juan Gator San Juan 02/26/19 08:18AM
  Re: Just bought and the pedal start won’t workRe: kevin Smellaflange kevin Smellaflange 02/26/19 09:11AM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/26/19 09:26AM
  Re: Just bought and the pedal start won’t workRe: todd amundson todd amundson 02/26/19 10:46AM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/26/19 10:48AM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/26/19 10:59AM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/26/19 02:09PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/26/19 08:16PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 02/26/19 08:32PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/26/19 08:43PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/26/19 08:49PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 02/26/19 11:33PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/26/19 09:08PM
  Re: Just bought and the pedal start won’t workRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 07:31AM
  Re: Just bought and the pedal start won’t workRe: Ryan Graeme Ryan Graeme 02/27/19 02:46PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 07:33AM
  Re: Just bought and the pedal start won’t workRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 09:13AM
  Re: Just bought and the pedal start won’t workRe: Don Ohio Don Ohio 02/27/19 12:26PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 12:58PM
  Re: Just bought and the pedal start won’t workRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 01:21PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 02/27/19 01:23PM
  Re: Just bought and the pedal start won’t workRe: Don Ohio Don Ohio 02/27/19 01:51PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 02:25PM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/27/19 02:39PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 02:45PM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/27/19 02:47PM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 02/27/19 02:58PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 02/27/19 04:08PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 03:46PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/27/19 03:54PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 04:01PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/27/19 04:22PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 04:33PM
  Re: Just bought and the pedal start won’t workRe: Don Ohio Don Ohio 02/27/19 05:03PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 04:37PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 02/27/19 04:45PM
  Re: Just bought and the pedal start won’t workRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 04:52PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 04:38PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 04:55PM
  Re: Just bought and the pedal start won’t workRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 05:12PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 04:56PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 05:05PM
  Re: Just bought and the pedal start won’t workRe: Don Ohio Don Ohio 02/27/19 05:09PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 05:15PM
  Re: Just bought and the pedal start won’t workRe: Dirty30 Dillon Dirty30 Dillon 02/27/19 05:20PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 02/27/19 05:40PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/01/19 08:45PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/01/19 08:48PM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/02/19 08:46AM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/02/19 10:25AM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/02/19 11:07AM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/02/19 12:15PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 03/02/19 12:22PM
  Re: Just bought and the pedal start won’t workRe: Stephen Simmons Stephen Simmons 03/02/19 12:50PM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/02/19 01:13PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/04/19 02:41PM
  Re: Just bought and the pedal start won’t workRe: Stephen Simmons Stephen Simmons 03/04/19 02:47PM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/04/19 02:49PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/04/19 03:39PM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/05/19 09:12AM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/05/19 09:27AM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/05/19 09:51PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/10/19 03:47PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/10/19 04:02PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/10/19 04:05PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/10/19 04:08PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/10/19 04:12PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/10/19 04:13PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/10/19 04:19PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/10/19 04:20PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/10/19 04:21PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/10/19 04:53PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/10/19 05:13PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/10/19 06:35PM
  Re: Just bought and the pedal start won’t workRe: Moped Lar (OFMC) Moped Lar (OFMC) 03/11/19 12:18PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/22/19 10:03PM
  Re: Just bought and the pedal start won’t workRe: Seth B Seth B 03/22/19 10:32PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/23/19 07:49PM
  Re: Just bought and the pedal start won’t workRe: Aaron Blair Aaron Blair 03/23/19 09:05PM
  Re: Just bought and the pedal start won’t workRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/23/19 09:33PM
  Re: Just bought and the pedal start won’t workRe: Owen Sims Owen Sims 03/24/19 10:15AM
