Help me remove this clutch...
Christian Roberts /
NOS daelim (trac) dp50 engine.
I’m confused by the design. Tomos-like at first glance, but haven’t been able to get the clutch off. Don’t see a place to use a tool. I’ve tried heat and mallet. Confused by the hole on top of the case with corresponding slot inside next to the crank. Confused by the threaded/spiral gear thing behind the pinion gears. Need to ask for help before I get frustrated and break something.
Wisdom please.
Re: Help me remove this clutch...
kevin Smellaflange /
big hose clamp & a nut driver still on it as a kickstand
♣Slew Foot♣ /
It has a squared crank. It prolly got worked into a groove.
Aero krill soak and use a 3 jaw puller.
Just yank it off there. If it gives you trouble whap it with a mallet a few times. That looks exactly like a tomos a3 transmission, must have sold their old dies and tooling to daelim. That's kind sick actually.
That hole on top of the case is for an oil pump. The gear back there drives the pump
The clutch and bell are slightly different from tomos, unfortunately you can't just stick this clutch in an A3. Same design though.
Christian Roberts /
all of the above and the bugger still won't budge. puller slips every time. i'm whappin away...nothing.
there's no way this should be this difficult.
by pict, u just gotta whack the bell clockwise to get it off that edge. holes on ouyer edge, once its loose should pull out pretty easy.
Christian Roberts /
Ended up bending the arms of this gear puller...
Moped Lar (OFMC) /
Those type gear pullers suck. You need the beefier two arm puller. (edited)
Did you try heating the hub before pulling it?
Christian Roberts /
I’ve gone at it with both, 3 jaw too.
Christian Roberts /
baked the whole thing in the oven for a bit...
Moped Lar (OFMC) /
After you tighten down the center bolt, whack the head of the bolt with a hammer. If it still doesn't pop, tighten it down some more and whack it again if necessary. This method has always worked for me. (edited)
Baking in the oven causes even expansion. Use a torch on the clutch hub itself. I usually go for map as its much hotter.
This^ Do not heat the crankshaft, just the hub with MAPP gas. Get a good puller like Larry said.
Christian Roberts /
could a bad needle bearing in the clutch drum have anything to do with this?
Christian Roberts /
been finding these little guys...
♣Slew Foot♣ /
Oh yep. Do the aero krill and the get an extractor bridge...
Christian Roberts /
any links you can send me? I'm having a hard time finding these remedies.
Christian Roberts /
I tried beefier pullers and they would slip. gave the wimpy puller a go because of its snug fit.
i'll try to get my hands on a torch
Christian Roberts /
maybe?
♣Slew Foot♣ /
An extractor bridge is an H shaped puller and ya make a jig to pull it off. Aero kroil is the brand name of wicking lube.
Christian Roberts /
victory.
how did u do it?
Christian Roberts /
aero kroil seemed to be the missing piece of the puzzle.
same problem with the drive gears though, stuck on the countershaft. any thoughts on how to get those off? With the front sproket off i have a little room to work behind the gears.
found out that those one way rollers fit behind the larger gear on the countershaft, similar to tomos.
Christian Roberts /
false alarm!
literally just pryed it free. and i think the gasket surface is okay too!
♣Slew Foot♣ /
Dude that is the s*** I have never seen anything work like that it is like aliens use it for the cattle mutilators it's like alien dual-use technology
