Re: Garelli clutch won't disengage
Daniel '' /
Could be the clutch has swollen, does the rear wheel spin freely when they engine is off? Before opening the transmission up I would try cleaning the idle circuit on the dellorto sha. If you look in through it from the side it clamps on from you will see a very small hole. Clean it out with a guitar string and compressed air. Also double check your points gap, I am pretty sure they are suposed to be at .45mm
