Re: tube shaped gasket for carb to manifold joint
Born to be WillD /
You can make a shim, people use aluminum from beer cans a lot, cut a strip and wrap it around enough times to fill the space as needed. I personally prefer HDPE from like a milk jug, thicker, more compressible and doesn't crunch as easily so you can reuse it.
