Re: tube shaped gasket for carb to manifold joint
Alan Jackson /
> Born to be WillD Wrote:
> You can make a shim, people use aluminum from beer cans a lot, cut a
> strip and wrap it around enough times to fill the space as needed. I
> personally prefer HDPE from like a milk jug, thicker, more compressible
> and doesn't crunch as easily so you can reuse it.
that sounds a good idea willD but HDPE only has a life expectancy of 100 years and as im in my v.late 50's the last thing I want is to die in an HDPE related accident.
I used carbon fiber tube 1mm wall to seal my manifold to silencer joint and it works perfect. but I couldn't find any the right diameter but have bought some a bit larger and will cut a tiny slot so it fits.
I will have a search for HDPE
