https://www.mopedarmy.com/wiki/Puch_wiring
Check out the wiki it may help. You should ground any “extra” wires your not using fromthe accessory coils.
If your not using all the switches I would look at the wiki how to wire for lights and clean up that wiring block and use some barrel connectors. (edited)
