Re: Motobecane Mobylette Repair
Stephen Keller /
Fresh fuel, good flow? New plug, correct gap? Check plug lead for cracks, same with the coil. Are you using the decomp? The choke? Is the horn on when you pedal, if so turn the kill switch to on...make sure it is there anyway. (edited)
