Re: Motobecane Mobylette Repair
kevin Smellaflange /
my moby has 678 miles on it it's a 30 mph bronze one.
some of the things i noticed were speedo was holding back a spinning front wheel ( easy check )...
grease will be a caked GO0ooo by now ....so variator grease fitting won't re-grease so 9mm spin out grease fitting & wire douche/scrape out the old muck...
the new grease comes out just passed the 2nd true arch /sirclip/snap ring inside the grease exit hole...
get some used snap-ring pliers, baby grease gun, new points & make an external condenser happen.
get a manual. a good micron tool set. stock pipe can be modded to work w/kits. ***flush tank w/white vinegar*** pm me w/needs
