Re: Honda Hobbit - rebuild stator or buy economical CDI?
Ryan . /
You will get no spark by just connecting it, the points open and close to cause the coil to charge and then the field to collapse which emits a spark. Look into how a high tension coil works. The short answer is either your HT coil is bad or your points are bad/wrong.
