thought i was having moped problems, rule out your horn n disconnect kill switch, so it aint messing up spark. make sure yr choke plate pulling up/attached right and check yr float/needle aint messed up. is the plug soaking wet or dry white?
Re: Polini E50 won't idle, poor performance, white smoke
