Not faulty but worn out rings.
Remove rigs from piston ( makes sure to remember what one was the top a bottom ring , tape works good). Insert ring into cylinder and use your piston to make sure its sitting flat and check with feeler gauge. Also your piston will show blow by. Sounds like a low compression issue. Your rings could be sieze on the piston but I doubt that (edited)
