Re: Polini E50 won't idle, poor performance, white smoke
I wish!
The new ring gap measured 0.18 mm. That is the 3rd picture
> Rocco Taco Wrote:
If any of us were there we would have your ass doing
> 50mph right now
Who is "us"?
OP - what head are you using? Are you sure it's covering the decomp hole where it mates to the polini cylinder?
> Mike Boyd Wrote:
> > 50mph right now
> Who is "us"?
Anyone that Would want to help him out. I know if I had some local moped guru like ken helping me out when I first started I would be a lot better off. Maybe you want money for your work, I just wanna see the kids ass going 50mph
Nah I've never made money on mopeds. Thought OP might be in CA but profile says they're in Seattle WA so I can't help either. Maybe stop by Magic Touch mopeds?
Hahahahahah
Who does? Lol maybe treatland probably not. (edited)
It is a Puch hi compression head. It covers the decompression hole.
Better to use an old hi torque Puch head and grind the nubs down. Been using one for a few years now. I also jam an Allen bolt set screw in the decomp hole. (edited)
Yea we could look at it for you, shoot us an email at mtm.seattle@gmail.com if you get too frustrated.
If you still have the cylinder off, try putting in the piston with the rings and then holding it up to a light source to see if the cylinder is deformed our out of round anywhere along the travel of the piston as it slides back and forth. Had a wallered out piston on a Vespa one and was stumped as to the cause of the problem until i tried this, and noticed that there was significant play
^ edit: i had a warped CYLINDER, not piston.
who here has "worn out" a cylinder?
This kid's grande cylinder was like, oval. I have no idea how he did it. We ended up replacing the crank and top end. It was the first time I had ever seen something like that
Overpriced Parts /
> Bob Selby Wrote:
> 15 Bing with 82 jet and 18 degree timing on points and no temp gauge WOW
> you are lucky it lasted that long ....
Yep unless it was a old casting like 2006 those things were basically bulletproof
The compression is 200 psi.
Could the cylinder be worn out with that compression ?
Chöschi21 C.K. /
That looks like a 38mm Head.
> Compression test was 60 PSI. I am going to get a new ring.
It's 200 now with a new ring?
Yeah after the new ring.
Runs exactly the same.
Dirty30 Dillon /
If it's billowing white smoke, I am tempted to suggest you have a shitty trans-side seal, or worse than that: case seal leak.
Chöschi21 C.K. /
Would think that too, are you shure the Case is good and did you use sealant on the case halfs?
I rebuild the engine using motoseal, new seals, and bearings. No changes from how it was running prior to the engine rebuild. I thought the trans seal was bad prior to the engine rebuild.
The bike had more white smoke prior to the rebuild. I would say it is 75% better.
What seals did you use? I had bad luck with the green seals from Treats. 2 different motors they started leaking at < 100 miles.
I used the treats green seals
Does your Tanny fluid look like liquid and smell like gasoline?
What kinda carb you running?
This thing could just have a big ass air leak somewhere. You need to know what your looking so you can check this stuff off your list. Il I can say is stay with and if you get mad just take a brake. Some fresh eyes from a family member or friend might help.
Good luck! I hope you get her or him running
The transmission fluid doesn't smell like gas or look thinner than usual.
I am running a 15 bing clone.
The case has a bunch of spider cracks and makes a creaking noise when on the kickstand. I am curious if one of the spider cracks might be causing a big leak. How would I rule this out as the cause of my problems?
Dirty30 Dillon /
> usual.
These are not cracks, these are casting mold marks.
That said, a proper leakdown test would rule out airleaks
> usual.
That 15mm clone doesn't make me happy. Iv always avoid clones, its not worth saving the money. real carbs hold their price
I am going to do a leak down test then go to the carb
Held 5 PSI for 5 minutes
choked up exhaus
It is the carb! I swapped carbs and it rips.
This is the carb I was running. About 8 months old. https://www.treatland.tv/NEW-bing-15mm-CLONE-carburetor-puch-moped-p/bing-15-clone-carburetor-puch.htm
I am thinking about going to a vm20. I should upgrade the pipe too. Anyone have build recommendations?
