Voltage regulator
Jason White /
My 1980 tomos bullet is stock 6v system. Since putting a kit on it, have been blowing bulbs. I bought this voltage regulator from treatland.
https://www.treatland.tv/trail-tech-voltage-regulator-p/trail-tech-regulator-7003-ac01.htm
It says use on 6v or 12v system in post, however when manual comes in box it says that it regulates voltage between 12v and 16v. How is it then compatible w/ 6v system as advertised on treatland? Will the 6v bulbs that are stock in the bike handle that 12v regulator? Do I need to change bulbs I'm using?
