Re: Voltage regulator
Brad William /
Shorter version, I think the regulator you have will be fine. But without changing the coil to a 12v version, you may not get any light at all until you're at medium rpms. The six volt coil just doesn't put out enough voltage for the lower threshold of the 12v regulator until the flywheels really spinning.
