Re: Voltage regulator
Ryan . /
V x A = W
25w/12v 2.08A
25w/6v 4.16A
12v bulbs will not draw more power from the stator. The only thing that would keep voltage low at lower rpm is that the 6v coil will have less turns (voltage) in it and may have thicker wire (amperage). It will without question power 12v bulbs of equal wattage. If you are concerned with low rpm output run an led tail.
