Re: Voltage regulator
Jason White /
Less concerned with low rpm brightness, more concerned about bulb life. I'm assuming it's safe to say the 12v bulb will hold up a little better, especially with this regulator. Will give it a shot, thanks!
My other question, if you look at this wiring diagram...
https://www.mopedarmy.com/w/images/d/d9/1980_A3_wiring_colored.JPG
I obviously need to tie the voltage regulator into my yellow line which goes up to horn, headlight, and back to tail light. Brake light however is off a separate coil wire, separate line. Does this need to be accounted for somehow with regulator? Only reason I'm paying such close attention to this is that I know the resistor is tied into brake light in this system and if that bulb goes it throws the whole system off.
