Re: No oil drain plug?
Born to be WillD /
I've got the side clutch gasket (which would be why it leaks, looks like nothing's there... and I got a spare drain plug if you need em. I've cut those gaskets out of cereal boxes and had luck, or get gasket paper, it's a simple one to cut, doesn't even need to line up perfectly, just cover the outside. sometimes it will need the space to keep the cover from pressing the starter arm tho.
