Re: No oil drain plug?
adam parsons /
> Born to be WillD Wrote:
> I've got the side clutch gasket (which would be why it leaks, looks like
> nothing's there... and I got a spare drain plug if you need em. I've
> cut those gaskets out of cereal boxes and had luck, or get gasket paper,
> it's a simple one to cut, doesn't even need to line up perfectly, just
> cover the outside. sometimes it will need the space to keep the cover
> from pressing the starter arm tho.
I was able to just drain it from the fill hole, but since you mentioned it, where a gasket should be looks like there's a bubblegum looking substance on it, I'm guessing to seal it. I haven't taken off the cover yet though to see.
