Rear break hub assembly issues
Hello I was an idiot and rage took apart my rear hub to check breaks and greas bearings, so after a few months I put it all together "so I thought" but when I tighten everything up the wheel won't spin, like I'm pinching a bearing. Any help appreciated.
Re: Rear break hub assembly issues
Your missing something:
Thank you that is exactly what I was looking for
The axle should roll smoothly in the wheel...BEFORE...you install the wheel in the swingarm (frame)...
Chöschi21 C.K. /
It shouldn't roll, if it rolls the Bearings have to much play.
It was missing one bolt on the drive chain side. I got I figured out! Thank you
Want to reply to this thread?
