1980 Garelli VIP 2spd rough time getting into 2nd gear
Barry (Bob) Brown /
1980 Garelli VIP 2spd and it has a rough time getting into 2nd gear, it seems smooth up to about 15mph and then takes way too long trying to shift into 2nd and sometimes wont or kinda surges,jolts. I drained and refilled the oil with fresh 30w. it looked pretty clean in the trans when I had the cover off. Think I just need to replace 1st/2nd gear rubbers?
Re: 1980 Garelli VIP 2spd rough time getting into 2nd gear
take it apart and clean it, theres probably gunk/rubber pieces hidden n lodged in there. those little rubber nipples suck.
> rubbers?
Make sure you have a good fuel flow and a clean carb first. This may sound crazy but it's a garelli. They do weird stuff from the simplest things..... Also make sure you have the air filter on it if it's completely stock.
Barry (Bob) Brown /
Taking apart today to clean, my service manual shows a different clutch as mine has 4 rivets so not sure how to tak this one apart. Anyone got a tip or ?
Moped Lar (OFMC) /
Take pics as you go.
Barry (Bob) Brown /
do I first drill out these rivets? This is the same clutch as mine.
Barry (Bob) Brown /
OK ran across a pop-rivet conversion thread and I drilled em' out - so I'm good.
Im o.k. mechanically, but at 51 I came back into mopeds after 35 year and first mistake was finding Moped Army - second mistake was finding treatland!
thx again for all the help on all my crap.
