Dellorto SHA 15:15 Jet Question
I have rebuilt an engine and installed it but can't get it to start up.
Here's what's new:
70cc TCCD kit
High comp head
new spark plug
super stuffy crank
case matched
new bearings and seals
stuff i already had:
dellorto SHA 15:15 carb
techno bullet pipe
I have a good spark. reset the point gap, and plug gap. cleaned points. I re-cleaned by tank, carb and replaced fuel filter. So i'm pretty sure i have good fuel and air delivery.
So i'm thinking my issue is the main jet size. The motor wants to fire. I'll get a pop or sputter every now and then. I bought a range of jets but they aren't the right ones. i need the bigger thread ones. the current jet does not have any markings so i can't identify the size. Any advice on a good range to start at?
Re: Dellorto SHA 15:15 Jet Question
70's
Do you think jet size is my issue with the no start?
Yeah,start with jet in the 70s and work down if rich.
Dirty30 Dillon /
If you don't know the jet size, how can you even start to think that it is tuned??
> is tuned??
If I cant get it started can I even start to get it tuned?
> it
> > is tuned??
The SHA is a single jet carb one of the easiest to tune. Aside from slides, you just have 1 jet to change. Too lean (won't start)? Upjet. Too rich? Downjet.
If it won't start, you need to establish a baseline to start with. Based on your setup, i would start with a low 80's jet, and work your way down into the high-mid 70's until it runs good. You said your jet does not have a marking on it, which leads me to believe you have a clone SHA, which work fine for the most part. You need to order 5mm Dellorto jets. Get them at treatland, or doscycles, mopeddivision... Get a temp gauge, it will help. And a few extra spark plugs.
Also, have you verified that your timing is correct with a timing light?(edited)
> Too rich? Downjet.
This is the kind of info I was looking for. Thanks so much! And I already have a temp gauge. I've spend too much time and money to seaze on my first ride.
> > Too rich? Downjet.
> Based
> down
> jets.
> gauge,
> on my first ride.
You'll want to verify your timing is correct too with a timing light, and ensure you have no vacuum/air leaks. SHA are prone to leaking at the mounting point, an O ring typically solves it.
With the clone SHA, just be a little more careful tightening the screws, as the metal/plastic may be of lesser quality. Post a picture of it if you can.
After ordering a range at treatland I found some jets that will work at my local scooter shop. Go figure. Also, I assume I have a cloned dellorto. Betcha can't identify this!
looks like some threads got pulled out?
