American Microcar/V1 wiring help
I'm looking for tips to wire my American Microcar with a V1 motor. It's the standard 6v points ignition. Nothing is connected right now; just a bunch of loose wires hanging. A hand drawn diagram of someone's existing wiring would be helpful. Thanks.
Re: American Microcar/V1 wiring help
There's also this
>>>taykoff [s2m] /
Seth probably has you covered, typical Minarelli wiring. Also, check this:
Microcar Manual
You may have it wired correctly, but the emergency switch is on and needs to be off? Essentially, it is just a built-in bypass for the dead brake light issue.
Sweet looking Microcar!
I didn't notice the emergency switch; It's wired the same as a Cimatti then. There may be a wiring diagram for Cimatti on Myrons Mopeds. But that's still basic Minarelli wiring. I'm pretty sure you're gonna have to have a resistor in the tail/brake light, iirc.
