Re: no spark
jim magera /
Okay, the plot thickens: I followed Stephen's advice (thank you) and
- if I ground the blue wire to the frame and run the black wire straight to the coil I get no spark
- if ground the blue wire to the frame and run the black via an alligator clip directly to the spark plug bypassing the coil I get spark.
So does that mean the points are okay and the coil is bad? I find that suspicious because the coil is new, installed by the previous owner. Here is a photo of the coil with the black wire connected directly from the magneto. Is it possible that another wire needs to be connected to the coil?
Want to reply to this thread?
