Sounds like an old Point Style A3 it has a c e v v flywheel you need an old-style high tension coil you need an old style condenser that is new start from there if you have an old Bosch HT coil it's good it will work they hardly ever go bad unless you can see a crack in it and it'll only be bad when it rains most part they're Bulletproof now you might have blown a coil and they're cheap to replace to test it you remove the coil from the circuit when it's isolated you take a battery and run the current through the coil it should magnetize enough to pick up a pen then you know you have a good coil the ignition coil you have to test differently you'll need a meter a probe a 9 volt battery A Match Pack and a little bit of reading in common sense
Re: no spark
Subject | Written By | Posted |
no sparkTopic by: jim magera | jim magera | 03/21/19 12:45PM |
Re: no sparkRe: Stephen Simmons | Stephen Simmons | 03/21/19 03:03PM |
Re: no sparkRe: jim magera | jim magera | 03/21/19 06:11PM |
Re: no sparkRe: Stephen Simmons | Stephen Simmons | 03/21/19 09:46PM |
Re: no sparkRe: jim magera | jim magera | 04/01/19 07:17PM |
Re: no sparkRe: ♣Slew Foot♣ | ♣Slew Foot♣ | 04/02/19 06:45AM |
Re: no sparkRe: jim magera | jim magera | 04/02/19 08:55AM |
Re: no sparkRe: jim magera | jim magera | 04/02/19 12:24PM |
Re: no sparkRe: Stephen Simmons | Stephen Simmons | 04/04/19 07:07AM |
Re: no sparkRe: pat splat | pat splat | 04/01/19 08:51PM |
Re: no sparkRe: jim magera | jim magera | 04/01/19 11:11PM |
Re: no sparkRe: jim magera | jim magera | 04/02/19 05:32PM |
Re: no sparkRe: pat splat | pat splat | 04/03/19 07:55PM |
Re: no sparkRe: ♣Slew Foot♣ | ♣Slew Foot♣ | 04/05/19 11:19PM |
Re: no sparkRe: jim magera | jim magera | 04/06/19 08:50PM |
