Fuel filter/line assembly
I'm getting my mopeds on the road in the near future and one of the tasks is to add in-line fuel filters and new fuel line.
I went to the local ACE Hardware to get line used by 2 cycle chain saws and filters that SHOULD fit that size line. It's pretty difficult to slip the line onto the filters, so I boiled up some hot water, dipped the end of the line into the hot water for a second to make it a little more flexible, and slid the end onto the filter with minimal effort.
Do you think this will cause any problems with the fuel line?
Re: Fuel filter/line assembly
Angry Hipster /
That line is garbage. Go to napa and get some bulk 3/16" fuel line and be done with it.
kevin Smellaflange /
i've had good luck w/some blue yamaha fuel line...
it's still been flexible when i change over the filters...
it tends to turn green if someone leaves it on too long, yellow & blue make green.
small filters shouldn't be a problem getting fuel to the carb, ie; pingel high flow petcocks to deliver a garden hose worth of aviation fuel, H-D w/ an ANDREWS N4
cam installed for example.
I buy the colored fuel line from Treatland, sold by the yard. Colored to match my bikes.
And paper filters w/ magnet in a 10-pack from Scramazon(edited)
that thin hard line you need to heat can lead to fuel starvation issues.
i buy mine by the foot from the local honda dealer.
> match my bikes.
I've never had luck with the paper filters on amazon, especially the cheap ones. I got box of 10, and they were not even filters, just a plastic container with 2 barbs on it and a piece of pleated paper bouncing around loosely inside, with no conceivable way of actually being able to filter anything.
Want to reply to this thread?
