replacing coil with an aftermarket one... from 2 prongs to 1, will it work?
Hey everyone - when i purchased my 1978 Columbia Commuter, the previous owner stated that it needed a new coil to start up. It had the original coil - black with a positive and ground (i think - according to the wiring diagrams i've seen) terminal (low circuit) and then the out of the high circuit leading to the plug. The new one i purchased doesn't have a ground terminal, just a positive and the high end to the plug.
Am i right in assuming the ground isn't necessary as it's grounded by the mounting?
Later this weekend i'll do some testing with a volt/ohm meter, but for now i thought i'd just ask.
Thanks!
Re: replacing coil with an aftermarket one... from 2 prongs to 1, will it work?
you are correct.
> John Fuhrman Wrote:
> Am i right in assuming the ground isn't necessary as it's >grounded by the mounting?
Yes, it's grounded by the mounting. A separate ground lug resembling the pos+ lug isn't necessary.
Want to reply to this thread?
