First project
Picked up a 82 Motobecane V50 yesterday thinking it was gonna be a piece of cake to get started and was sadly mistaken. Seems to have compression but I’m not sure how to check compression. Can’t really tell if it has spark or not. Don’t know what position is which on the gas lever or the kill switch. Positive is I took the carb apart today and cleaned it out.
I’m totally lost and any assistance would be greatly appreciated. #NewMember
Re: First project
Woof, you messed up. Mobys are not the easiest intro to mopeds.
Re: First project
Moped Lar (OFMC) /
Sell it and get a Puch. That’s what I would do.
Re: First project
first off you're gonna need the flywheel...
https://www.treatland.tv/USED-motobecane-NOVI-stock-points-flywheel-p/used-motobecane-novi-flywheel.htm
or you could start by dumping money into this...
https://www.treatland.tv/motobecane-CDI-p/motobecane-cdi-ignition.htm
but yeah you're gonna go nowhere w/o spark
Re: First project
Def no spark without a flywheel. Your gonna wanna ditch the gurtner carb for a 15 Bing and shorty intake.
Re: First project
^he means 15 dellorto sha.
Re: First project
Go back to seller...….he probably has parts lying around,including that flywheel.
Re: First project
yup, thanks man. my bad too many beers///
Re: First project
^this. Because without the air filter cover you'll never get it to run right. And that cover is hard to find.
Re: First project
#fuckmobys
Re: First project
kevin Smellaflange /
moby's forever!
Re: First project
Red one is the best one, fuel valve, pull to the outside of the bike, kill switch, rotate right, and then never touch it again! Use decomp to kill the engine. Drain fuel, replace with fresh, if tank is rusty make sure to ad an inline filter. Did you remove the flywheel or did the bike not come with one? The aftermarket carb mentioned is a good bet but I run the stock gurtners with no issues.
Re: First project
No the bike moped was complete. I took the pic when I had already started taking it apart. Did get it running but this carb is a piece of crap. That’s all I need at this time. Any link on a decent Carb???
Re: First project
Send me a link for that carb. How much are they?
Re: First project
Does it bolt up or do I need to change things around?
Send a link. Which one do I need?
Re: First project
derek from black pipes moped gang /
Delorto SHA 15.15 with a motobecane av7 shorty intake. Look up what jetting range you’ll need and buy a handful of jets in that ballpark. Doscycles or treats are both good places to buy from.
Re: First project
I have a 1982 v50 not sure which intake etc. If I send pics would that help?
Re: First project
Your engine is an av7
Want to reply to this thread?
