Red one is the best one, fuel valve, pull to the outside of the bike, kill switch, rotate right, and then never touch it again! Use decomp to kill the engine. Drain fuel, replace with fresh, if tank is rusty make sure to ad an inline filter. Did you remove the flywheel or did the bike not come with one? The aftermarket carb mentioned is a good bet but I run the stock gurtners with no issues.
Re: First project
