Re: Bogging on 1st gear ? i tried everything ! :(
> Anthony Vargas Wrote:
> > > Alright so I forgot to mention that I’m not running stock , this
> bike
> > > came with a 70cc kit and a biturbo that I removed and used a chrome
> > > bullet instead , seems like my issue might just be the carb that’s
> not
> > > adjusted properly, or a leak on the magneto side seal , I know for a
> > > fact that my lx was running fine and then out of no where, the
> bogging
> > > started happening which is weird and unexpected.
> > When I said that an exhaust leak typically would not cause running
> > issues, I was referring to slight leaks. A large leak at the flange
> > could cause issues, but I doubt that is your problem in this case.
> > Given the fact that your jetting is not way off, or at least not as
> far
> > off as originally thought, I would replace the magneto side seal
> before
> > you continue. Be certain you reinstall the stator plate exactly where
> it
> > came from, and that you do not lose the flywheel pin/key. When you
> > remove the magneto side cover, look for oily liquid seepage, which
> would
> > be indicative of a bad leak.
> > And remember when replacing seals, the hollow side should face the
> > pressurized side of things. (Given that logic, I never understood why
> > the clutch side seal faces the transmission instead of the crankcase
> on
> > an e50 though)
> Wow guys I found my issue , so before my bike had so many air leaks and
> I guess after I finally fixed all of that my air mixture screw was
> turned in all the way , I adjusted my idle screw and air mixture screw
> to get it perfect and guess what ... no more bogging , I took it out for
> a spin. For 30-45 min and everything sounds great , I might need a new
> spark plug cause my current one looks fouled . Thanks for all the help
> guys I really appreciate it ! Time to rip !!!
Glad you fixed it,BUT that air leak you found had something also to help it run.
Want to reply to this thread?
