WTF is wrong with this Tomos ignition? A3 12v no spark
mike sweet /
3 Wire 12v CEV Stator:
-Black wire to coil
-Blue wire external ignition ground (stays grounded but when circuit opens, supplies power/ return path to brake lights)
- Yellow lighting coil
Bike WAS running fine, everything working (no horn present). No changes and suddenly has no spark EXCEPT if you wire two things differently:
-Flip flop blue and yellow wires: yellow lighting coil wire to brake light circuit, blue wire to lighting circuit - Bike runs great and everything works as it should
OR
-Spark only: blue wire to ignition coil (Does NOT work if I go black wire to coil & blue wire to ground)
I have the kill switch disabled to rule that out (black wire only to coil, not connected going to switch)
I've tried a spare stator. It worked perfectly immediately and now I'm having the same issues.
Really losing my mind over here. Got about 8 hours into troubleshooting this thing.
