Re: WTF is wrong with this Tomos ignition? A3 12v no spark
♣Slew Foot♣ /
Just curious are you trying to put the horn in the circuit if you are then it has to go to the horn before the headlight and there's a double yellow that goes up to the lighting and then it does all this funky stuff and it ends up as your turn signals the horn might not be autonomous horn and not have the right resistance or you have your terminals flipped on it
