Re: No V1 crank shim?
Guillaume Guite /
Yes there is, and there is none on the diagram. But on the wiki it says "There's a crank shim that ALWAYS lives on the magneto side of the crank. The v1 service manual does not show this shim in the exploded diagram, but it's there. Some engines even have two of those lil' buggers! Whoa! In case you lost yours, McMaster-Carr can help you. The size of this shim is 18mm ID x 24mm OD x .6mm Thick. You might have to double up two .3mm thick shims to get yer .6mm "
Rebuilding a Minarelli V1
