Re: A3 rear wheel sealed bearing conversion
Buddy Shirey /
You'll definitely need a spacer on either side of the wheel between the wheel and swingarm. You don't necessarily need one that goes the whole length of the axle. The main thing is having a spacer between the bearings and then spacers on the outside of the wheels. Also make sure you space your wheel enough away from the lefrt sir of the swingarm so that the chain lines up straight with your sprockets.
Want to reply to this thread?
