Re: Different Honda Hobbit stator.
Jack Nielsen /
Ryan: lets go back to the original OEM stator. I went and removed the Treats points from the stator and retested the exciter coil and the ohms reading was correct. The coil is good. So why when the points are installed does it give a bad reading. I tested them with the points both physically open and with a insulator. Any suggestions. Jack
