Re: FA50 not starting after new tires
Dr. Mantis Toboggan M.D. /
I'm assuming you're holding the rear brake lever when you're kicking the bike over, correct? Also, make sure the kill switch is in the ON position. You may want to clean or just replace your spark plug to make sure that's not the issue. Check to see if any of the electrical wiring got disconnected during the tire install.
