1979 Motobecane 50V Magneto Wiring Issue
OEM Novi Condenser Wire: Blue (Connects to Stationary Screw on Points)
NbK External HT Ignition Coil Wire: Grey (Connects to ****)
OEM Novi Grey Internal Ignition Coil Wire: Brown (Connects to ****)
Re: 1979 Motobecane 50V Magneto Wiring Issue
kevin Smellaflange /
grey is exciter 6v
brow tail light maybe 12v
the bike might be 6v & 12v @ the same time on the same bike...it depends on the model
My question is where does each wire need to be connected.
Thank You
Maybe this will help your confusion :
https://www.mopedarmy.com/wiki/Motobecane_wiring_diagrams
I would think other than the wires from the light coils , which should be self explanatory , the wire from the ignition coil , along with the blue from the condenser and a grey wire from the HT coil would be connected to the points .
Yes the others are pretty self-explanatory. It was in pieces when I bought it so I didn’t get to see how it came apart and no pics I have seen show a clear enough connection to the points. Damn that’s a tight fit getting all three wires hooked to the points!
