Re: ZA50 Stator + Multmeter = Explain to me like im a total numbskull.
Seth B /
Throw your meter across the room. You don't need it now.
Clean your points properly, then set the point gap correctly. Disconnect all six stator wires from the wiring block, and wire for spark only. Instructions are in the wiki. Then once it's running, study the wiring diagram, also in the wiki, and reconnect your other systems.
